Announcements
problem combining components after installing update
WPGinfo
WPGinfo
When trying to combine several components I encountered the following problem after installing the latest update.
  1. I create a single simple rectangular component
  2. I create a single simple  square component
  3. I 'move & copy' the square >> now I have a rectangle & 2 squares
  4. I align all components so the rectangular components and the squares touch
  5. I mirror the squares [midplane of the rectangle] >>  now I have a rectangle & 4 squares
  6. I now whish to combine all components into one component
  7. click combine-icon
  8. select the rectangle as 'target body'
  9. select the four squares
    == == == here is where things go 'wrong'
    when selecting the first 'tool body', the rest of the squares / components are no longer visible.
    They cannot be selected
Since this first happened this morning, I found out that - although the 3 remaining 'tool bodies' become invisible - moving the mouse over the area where these bodies are supposed to be, reveals a semi-translucent ghost of the component. This 'gost can be selected. Now rinse & repeat for the other elusive components.
This has the desired end-result.
However, IMHO this seems a bug.
Please share your thoughts on this ? and 'fix'this?.
Thanks you for your help,
Willem
davebYYPCU
Copied Components are linked, what you do to one, will cascade to all copies.
Make your cubes as new bodies in the rectangle component, or just make the one body in the first place..
Might help....
