Press Pull issue
I'm not sure if this is a bug, or something weird with this file/my settings, but I can't work it out, so figured I'd check here. Hopefully it's something someone's come across before, and can explain how to fix it.
I have a cylinder:
The bounding box dimensions are what I'm looking at here. (I believe the height is bigger than the length due to it not being exactly horizontal, but that's not my concern anyway)
I then select the end face of the cylinder, and use press pull to move it 0.1mm
Looks a bit too much... well, that's because it is...
Suddenly my cylinder jumps from 1.5mm, to 2.25mm...
Is there some setting or previous action within the document that could be causing this? Pretty much the only things that I've done so far, was scale the entire model down, and then used offset face to make the diameter of the cylinders bigger (which worked precisely to the measurement I had specified.)
There are 111 of these cylinders in the scene, and it's happening to all of them.
