Announcements
Post processor for much 3 on 3d printer housing
Hello and thanks  for reading !
How can i write a post processor that turn the head of extruder around on c axis in tool center point when the extruder is moving
serge.quiblier
Hi @Anonymous ,
there is nothing you can do on the toolpath inside Fusion to solve this issue.
Some trick can be done in the post, it's what is called a drag knife for the cutting machine.
It means we can use the consecutives moves to calculate the angle between the horizontal direction pointing to the right, and the direction of the current move.
The only issue would be in a corner of the part. For example, it will go to an endpoint at 0° then switch to 90° before depositing on the next move. So it will rotate 90° on the spot.
I can provide a cutting post using this functionality as a template. But i can't write a post for you.
Have a nice day.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
HI Serge.Q
THANK YOU FOR YOUR REPLY VERY MUCH !
YOUR SOLUTION IS NOT EXACTLY WHAT I SEARCH, BUT MAYBE HELPING ME, HAVE SOMETHING TO START WITH!
I think to use the capabilities of the rotary Table Axis
SO CAN YOU SEND ME YOUR POST PLEASE?
Have a nice day.
Regards.
serge.quiblier
Hello @Anonymous
i noticed, i have never give you the sample post.
Please find a "crude" fff post using the knife logic.
It is shared fo educational purpose, to show the concept.
It may or not apply fully to your device, and may need enhancements.
Regards.
Serge.Q
cam.autodesk.com
