Possible Bug: Copy - Paste Component Not Available In Some Instance
bryan_moosman
bryan_moosman
So interesting potential bug - I'm trying to copy a part from a history-captured design and it won't let me paste the component into the upper level assembly (which is not history-driven) to reuse as a general object.  However, if you copy the same component into a new design (even not saved), then copy that item, then paste it back into the original upper level assembly, it works...
What's up?  Is this intended functionality?  Seems kind of odd...
dsouzasujay
Hi @bryan_moosman ,
Can you please explain the problem in a screencast/video, Also attach the Fusion 360 File>Export your *.f3d/*.f3x file to your local drive and then Attach it here to a Reply.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
