I want to set the position of aluminium profiles inside of doorway. I have created a construction plane from outer surface of the wall at the distance I need. Then I have created a sketch on this construction plane and projected a wall to receive a lines where I can link my profiles by joints. This worked with aluminium profiles with 90 degrees in corners. But if I want to link aluminium profiles with rounded edges (with help of fillet) it doesn't work. How I can do it?
