Fusion Support
polygon will not change the amount of sides when I change the user paramither
2 REPLIES 2
sander.koorevaar.online
249 Views, 2 Replies
When I make a user parameter (set to 10) without a unit and then use it for a polygon in a sketch, the polygon will have the amount of sides where I set it to in the user parameter. But when I change te parameter it doesn't want to change the amount of sides he has.
Can someone help me??
Tags (2)
2 REPLIES 2
The number of sides in a polygon model sketch are not editable once the original entry has been committed.  This applies to manual entry or if you are trying to use a parameter to do it.  It is a shortcoming of the Fusion 360 sketch engine.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
A workaround would be making the polygon manually using circular pattern.
Just did it and it's OK.
Technology Administrators
