Point to point move not accurate.
I'm having an issue moving an object from one point to another. Selecting a target point in the center of the bottom of a cylinder and moving the object from that point to a point on the corner of a cube 200mm or so away. The issue is once I check the location of the point that it arrives at, the center of the bottom of the cylinder is about 4mm off in the y axis. ( -4.768E-06 mm ) It should show (0). The cube's corner has not changed, and it is still in the right spot. Y - (0)
The same error occurs with a point to point or point to coordinate move. I have to say, while not especially intuitive, I am a big fan of Fusion360's toolpath planning - especially for straightforward CNC 3 axis machining. On the other hand, moving from one position to another accurately is about the most basic operation I could ask for in cartesian space.
Can anyone suggest why Fusion won't make this move accurately?
David
