Please help - default grid unaligned in Fusion 360
a_s_d4
Observer
a_s_d4
Observer
Observer
This happened today after an update I think in one of the files I'm working on - but the problem has seeped out of it and into Fusion 360's default behavior!
Below is a brand new file, where I've made a sketch that is 5mm wide. On the sketch grid, it lines up perfectly. On the layout grid as you can see, it 'sticks out' by 5mm.
-This is on Orthogonal view, not perspective
-3D Sketch has been disabled
-Layout Grid is set to fixed, 5mm spacing with 10 subdivisions
-This is a fresh install of Fusion 360, I've done factory reset on settings and reset it / removed the cache
-This is done on a blank, new document. All other documents and files now have the same off by 0.0005 error on their grids
Please help! While I can work with the sketch grids, this is absolutely driving me mad due to my OCD :(((
Phil.E
Can you attach a Fusion design, or give a link to a design like this?
Phil Eichmiller
Software Engineer
Quality Assurance
