Fusion Support
Please help: Cannot extrude these 2 screw holes into the model. No target body found to cut.
5 REPLIES 5
nmg138
85 Views, 5 Replies
Please help. I would like to 3d print this with the holes into the model so I can add in wood screws. I have attached the model file below. Thanks a lot 🙂
5 REPLIES 5
g-andresen
in reply to: nmg138
The body is a surface body.
However, you need a solid for extruding holes.
Unfortunately, you have deactivated the history so that the construction cannot be reproduced.
günther
nmg138
in reply to: g-andresen
is it possible to convert a hollow body to a solid one.
nmg138
these are the surface errors that are preventing the extrusion. i guess they need to be stiched or patched.
g-andresen
in reply to: nmg138
Here is a rustic form using boundary fill and mirroring of one half.
günther
nmg138
in reply to: nmg138
thanks so much andresen :)))))))))
