Announcements
Plasma Cut Paths Will Not Generate
Each time I try to build a cutting path for these two parts, the program will not generate a path form.  I am fairly new, and I have had a great deal of success with Fusion 360, but a little help would be greatly appreciated.  Where am I going astray here?
jhackney1972
This design probably came from a imported SVG file.  I have found that a lot of the small profiles have to have the path reversed to have them succeed.  The longer profiles often will create a toolpath with the first direction.  I do not know the cause of this.  So I suggest you take it is small sections using multiple process steps in order to get a finished toolpath.  By the way, it does not seem to matter if you use the sketched model or the extruded one although it is much easier to create a proper setup on the extruded one.
John Hackney, Retired
rdengineering66
I found a few problems with the latest release and plasma.
I had the same issue when I tried to regenerate an older file and eventually found that the problem was fixed if I opted for "roll round corners"  in the passes tab. I have just tried with yours and it generated for me once I chose that option, took a while because of the complexity but it generated in the end.
