Hi @p.qlliar, thanks for posting.
The first thing that I would check are your graphics card drivers. Check if you have installed the latest version of them.
You can also check if the Fusion does not use an integrated graphics card.
- Click Help icon in top-right corner in Fusion 360 window.
- Go to Support and Diagnostic.
- Choose Graphics Diagnostic.
If the integrated card is on, try to switch Graphics driver in Preferences (also top-right corner in Fusion 360 window, next to Help option) or try to switch between different option in Graphics > Display section also in Preferences.
Sometimes the display issues may be caused by using docking station. If so, if it is possible, try to connect the monitor directly to the computer, and then check if the issue still occurs.
Additionally, if you are using macOS, check if graphic switching option is disabled:
- Select Preferences from the Apple Menu.
- In the Energy Saver preferences, disable the option for Automatic Graphics Switching.
