I am trying to create a body, comprised of pipes to create a net design around an object in my kitchen. I originally planned to follow the advice from this video https://www.youtube.com/watch?v=wpWXSI44n7E - which predated the latest mesh improvements.
My design is a little simpler than the example, being a cylindic shape with paralel, 90-degree top and bottom, with no fillet. I'm fine until I get to the part about creating the pipes. Fusion360 refuses to create a pipe when all edges from the side are selected. Getting this error but I don't see a problem: " There was a problem combining geometry together. If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
So I have tried to create this a few lines at a time, but I keep running into the problem cited above. See screencast. Model is attached.
Can you help me identify where I've gone wrong and how I might go about fixing it?
Fusion360 Version 2.0.11415
