Hello all,
I'm designing a glass lamp enclosure with solder and copper between the glass planes.
My sketches consist of a multitude of profiles and lines.
The glass is created with a simple extrude on the profiles, and the soldered joints are created with the pipe command.
I've been able to create a variety of the soldered joints, but have ran into an issue when trying to pipe around a rectangular path. If you take note of the timeline on the screencast, it does indeed show that I've encountered a similar warning multiple times, with the other rectangular paths on the side of the enclosure I'm working on.
The pipe I'm using in the images and screencast is supersized for visibility purposes.
The screencast illustrates what occurs when I try to pipe around a specific section of that path. (Warning: The sweep could not create a valid body)
SCREENCAST: https://knowledge.autodesk.com/community/screencast/331ec8bb-1ee5-499f-bf4b-a1d197652be9
When I remove one of the lines, destroying the profile, then create the pipe, it appears to function. Then I recreate the profile by adding the line I deleted. Should I settle for this fix and move on?
Is there some key functionality of the pipe command that I'm missing, is this an error on Fusions 360's behalf, or am I using the tool too esoterically?
Thank you,
Dmitriy
