I have a simple demonstration file, (unexpected behavior)
The idea was to reduce a comprehensive workflow to something simple,
(original file 26 bodies - common mirror plane - other files may have more)
This file has 3 sets of mirrored bodies, I wished to condense to one body, (saves 3 (13)mirror commands and then 3 (13) combine joins - pita, as standalone sets - none of this required if one body)
sketch a line on center, (existed) join a pipe to the bodies, Fusion only joins it's body to the first body in the list (in 2 files I tested)
1. Pipe as a cut - cuts all 6 bodies (expected)
2. You can Extrude Join with an overlapping profile. - (including the pipe!)
Could do with some love...
