Announcements
Physical Materials - density not accurate enough
evilc
Message 1 of 14
evilc
The density field for Physical Materials only allows values to 3 decimal places - I need 4
Carbon Fibre for example, for me at least, is 0.0015 g/mm3
eg for a part I have had cut from a design in Fusion that actually weighs 1.65g, 0.001 yields a weight of 1.094g and 0.002 yields a weight of 2.187g - a ~50% difference in weight, which is unacceptable
Please fix
Replies (13)
Message 2 of 14
g-andresen
If necessary you can change the settings in your preferences:
Message 3 of 14
TheCADWhisperer
Message 4 of 14
evilc
This is pointless - you don't need my design to repro this issue, it repros with all designs
I am asking why the "Density" field here only accepts values to 3 decimal places, I need at least 4
The "Scientific notation precision" setting mentioned above has no effect on this dialog
Message 5 of 14
TheCADWhisperer
Interesting you should write that.
In my FEA class we create our own custom library of materials and enter any values that we need.
If you had given me your file - I would have used it in an example video.
Good luck with your Fusion 360 endeavors!
Message 6 of 14
evilc
Can you show me a screenshot of that dialog with 0.1234 g/mm^3 in it?
Message 7 of 14
TheCADWhisperer
or...
Message 8 of 14
evilc
Hmm, interesting
Sample project attached, but surely this is an application-wide setting?
Message 9 of 14
evilc
No idea why I cannot get that box to show that many decimal places, but I figured out how to add a material with the correct density by using the full material library.
All I did before was open that dialog, duplicate Steel (What I guess is the default material for all bodies), rename it and try and type my value into that dialog
As soon as I worked out how to use the full materials library, was able to create a new material with the correct density, although it still rounds to 3DP in that dialog, the Mass is correct
Message 10 of 14
TheCADWhisperer
Click on the Advanced.
Message 11 of 14
aeytwp
I have exactly the same problem and a search bring me to this post.
The density in my material setting box only limit to 3 decimals.   Can you please elaborate on how did you solve this problem? How to add a new material (not duplicate) the full material library?
Message 12 of 14
TheCADWhisperer
@aeytwp
Can you Attach your *.f3d file here?
Can you Attach some screenshots of what you see?
Message 13 of 14
aeytwp
Please see my screen cast.
https://autode.sk/3Is0RTr
I put in more than 3 decimals, but it rounds to 3 decimals.  Please advice.
Message 14 of 14
aeytwp
This screencast is my unit setting, https://autode.sk/3L0gxPl
Please advice how to make the density setting accepts more than 3 decimal points.
