Fusion Support
Physical Material Not Changing
2 REPLIES 2
davyjacksr
320 Views, 2 Replies
Physical Material not changing to the selected material in the drop down - it continually reads as various - I reset to the default preferences and restarted the Fusion program and the failure to change still persists. What am I missing - Thanks
2 REPLIES 2
James.Youmatz
in reply to: davyjacksr
Hi @davyjacksr,
Can you be more specific as to what is happening? Is this in the simulation environment? Can you post a screenshot and share the file so I can investigate.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
davyjacksr
in reply to: James.Youmatz
Thank You -for the reply - Apparently it was a boot error in my computer - the material change has been working properly the last couple days - Again Thank You!
