Physical Material not changing to the selected material in the drop down - it continually reads as various - I reset to the default preferences and restarted the Fusion program and the failure to change still persists. What am I missing - Thanks
Hi @davyjacksr,
Can you be more specific as to what is happening? Is this in the simulation environment? Can you post a screenshot and share the file so I can investigate.
Hi @davyjacksr,
Thank You -for the reply - Apparently it was a boot error in my computer - the material change has been working properly the last couple days - Again Thank You!
