I've tested with a number of different projects and different files just now.
When I right click on a component to select "Physical Material" or "Appearance" and apply my preferred options to a selected component, upon clicking "close" at the bottom of the dialog box, the properties are reset and the component goes back, to being its generic material/appearance gray colour.
Wasn't there an OK button before?
Applying Black Opaque Plastic property.
After clicking "close"
You can see the object returns to normal. No component color toggling is enabled. I have not changed any settings in F360 for quite a long time now.
This happens at the component, body, and assembly level. No change in appearance after the dialog is closed.
In the above screenshots, the component was Derived into the current assembly.
If I go back into to the original component file and change the properties, the same thing happens; shown below.
The properties ARE changed, but the appearance is not.
I simply cannot change the appearance of components anymore. Is there a viewport setting that controls this?
