Personal version cannot even handle a sketch for a 400mm x 600mm CNC Spoilboard?
mark.lawlerGZ94E
mark.lawlerGZ94E
I'm in the software industry, so I totally get making $. However as a CNC hobbyist I don't think it should take over 3-10 mins to select then try to copy 20 straight lines for a CNC spoilboard grid sketch on a high end game machine. This release is broken.
TheCADWhisperer
seth.madore
Hi Mark,
I don't think it has anything to do with the licensing of the software. As @TheCADWhisperer  suggested, can you share your file?
Seth Madore
mark.lawlerGZ94E
Here is an export.  Pretty simple file with 2 sketches.  Just a bunch of straight parallel lines at this point.  Try to select 3-10 of them with the select menu and once selected try to press "m" for a move/copy operation.   Spinner rotates forever, and a progress bar in bottom right hand corner "scrolls right" forever.  Other way to recreate is simply select one line, press M, wait for move/copy popup, then check "Create Copy"...  Same result...  Exported file attached.
g-andresen
That does not surprise me.
Generally in Fusion you don't create layouts in sketch mode, but with features/faces in solid or surface mode.
You create an element in your sketch and from it the corresponding feature (e.g. groove) and then duplicate the groove in solid mode.
günther
