The Fusion 360 installation routine does not have rights to your local hard drive that it needs to succeed. This is shown in one, of a few lines, in your log file. I have selected one to show.
I believe the solution to this is to make sure the user "JChipukites" has administrator rights to your hard drive or to the folders required for installation. Looking back on your past responses, I can assume you have no idea how to assign the required rights to your hard drive. I will attempt to show you how.
Open up the Windows Control Panel and select User Accounts.
In User Accounts, you will see the user name "JChipukites" just like you see my Windows user name John Hackney shown below. Note below my name after the blurred out line you will see I am the Administrator of my computer. To see your account, you "must be logged into Windows" using that account. If you do not then select Manage another account as indicated.
Last you need to select "Change your account type" and choose "Administrator" the then select Change Account Type as indicated. Mine is grayed out since I am already an Administrator of my computer.
Once this is done close all Control Panel windows and "Restart" your system. Make sure you log into Windows using the account user you just created as Administrator.
Last, find the Fusion 360 Streamer installation EXE and right click on it and choose "Run as Administrator".
If this does not solve you issue then I would suggest you seek out a qualified computer specialist to help you out.
John Hackney, Retired
