Announcements
Performance issues with drawings
johanGGBJT
Message 1 of 18
johanGGBJT
Lately it has been very slow to open any drawing. Opening a very simple drawing of a part takes 28s and a small assembly 30s so it does not seem to depend on the size of the file. My collegues experience the same problem and it started a few weeks ago, before that it was a huge difference. Any help or advice on this would be greatly appreciated!
Replies (17)
Message 2 of 18
CGBenner
@johanGGBJT
Welcome to the Community.  Could you share some information about the type of system you are working on?
Chris Benner
Industry Community Manager – Design & Manufacturing
Message 3 of 18
johanGGBJT
Thanks for the quick reply Benner, much appreciated!
Below is the spec.  copied, please let me know if three's anything you're missing.
Processor AMD Ryzen 7 PRO 6850H with Radeon Graphics 3.20 GHz
Installed RAM 32.0 GB (31.3 GB usable)
System type 64-bit operating system, x64-based processor
Graphic card Nvidia RTX A2000 12 GB
Message 4 of 18
CGBenner
@RajkumarIlanchelian any other questions for @johanGGBJT ?
Chris Benner
Message 5 of 18
RajkumarIlanchelian
@johanGGBJT Thank you for providing the hardware specs. Here are a few things to check out that can help us identify what could be happening.
1.Is the issue only when opening the drawings? (or are you seeing the issue opening their respective designs as well)
2. Does your machine have any pending OS updates or graphics updates pending?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 6 of 18
johanGGBJT
Hi @RajkumarIlanchelian
Please see me reply below in bold.
1. Is the issue only when opening the drawings? (or are you seeing the issue opening their respective designs as well)
Yes, it seems to be only the drawing and not design. It also seems to not depend on the size of the model, only minor differences between a huge model and a small part.
No, everything should be up to date.
Message 7 of 18
RajkumarIlanchelian
@johanGGBJT Apologies for a delayed response. I am going to tag a couple of our engineers that can follow up to see what is the performance issue specific for drawings.
@mohammed.aliTDPXK @suryawa Can we please work with @johanGGBJT to understand what could be happening such that only drawings are seeing a performance degrade?
Autodesk Fusion
Join Fusion Insider
Message 8 of 18
suryawa
Hi @johanGGBJT ,
Could you please let us know,
If it is a general issue that you see with every drawing?
Or
There are some specific designs/drawings that shows the performance lag?
It will be a great help, if you can share the specific data for investigation.
Amit Suryawanshi
SQA Fusion 360
Message 9 of 18
mohammed.aliTDPXK
Hello @johanGGBJT ,
Can you try clearing your cache to see if this resolves the problem?
It may also be useful if you could send us your diagnostic logs to have a look at too.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 10 of 18
johanGGBJT
Hi Amit,
Thanks for your reply.
It seems like the problem is general and not depending on the file/design.
It is only a minor difference in time when opening a large/complex design compared to a very simple one.
Message 11 of 18
johanGGBJT
Hi Mohammed,
I tried to clear the catch but could unfortunately not notice any diffrence.
Attached you find the diagnostics log.
Message 12 of 18
mohammed.aliTDPXK
Hello @johanGGBJT ,
Thanks for sharing the diagnostics files, I am checking with my team for any clues if I can find, meanwhile please also share share the files for which you are getting issues, you can also DM me if you don't want to send it here.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 13 of 18
johanGGBJT
Hi again Mohammed,
And thanks for the help.
I do not have any particular files since the issue seems to be general and affecting all files.
As mentioned previously it takes a long time for opening any file (+25s) and it is only a minor difference between opening huge and small files/designs.
Message 14 of 18
CGBenner
@johanGGBJT @mohammed.aliTDPXK
Has this been resolved?
Chris Benner
Message 15 of 18
johanGGBJT
Hi Benner,
I'm afraid not but thank you for following up on this.
Message 16 of 18
CGBenner
@mohammed.aliTDPXK
Hi, do you have any new input or ideas for @johanGGBJT ?
Chris Benner
Message 17 of 18
TrippyLighting
While it might diminish performance, could you create a screencast and simply record while opening a drawing and an assembly?
Message 18 of 18
mohammed.aliTDPXK
Hello @johanGGBJT ,
Sorry for the late reply, Is this issue only on 1 machine, could you just check if you are facing this issue on another machine?
In any case. just send us (DM me) any of your files which has this issue and we will see if we can replicate at our end.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
