Announcements
Pb with Update of fusion
Message 1 of 8
Hello
I have pb with the curent update of fusion.
Here you are the log file....
An idea ?
By advance, thanks a lot ....
Traceback (most recent call last):
File "nspylib.zip\process.py", line 1542, in execute
File "nspylib.zip\process.py", line 2834, in execute_without_errorhandling
File "nspylib.zip\process.py", line 1447, in execute_without_errorhandling
File "nspylib.zip\process.py", line 2808, in _load_deployapps
File "nspylib.zip\process.py", line 2689, in _load_appmanifest
File "nspylib.zip\manifests.py", line 426, in open
File "nspylib.zip\manifests.py", line 274, in open
File "nspylib.zip\netlib.py", line 570, in __call__
File "nspylib.zip\manifests.py", line 267, in _open
File "nspylib.zip\netlib.py", line 477, in __call__
File "nspylib.zip\netlib.py", line 154, in __init__
urllib.error.URLError: <urlopen error <urlopen error [Errno 0] Error>, url:https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...>
Replies (7)
Message 2 of 8
Any ideas ?
Please ....
Message 3 of 8
I have tested this URL (on this machine and on an other one :  it answers 404
How can the process try to upload an unknown module ?
Message 4 of 8
Bonjour
Je n'ai pas eu de réponse ? Et j'ai toujours mon pb ....
Personne ne peut m'aider ?
Merci
Message 5 of 8
patrick.emin
Bonjour @Anonymous notre forum en français est ici. Vous pouvez exposer votre problème en français là-bas si vous le souhaitez.
Hello @abcr.bouquet our forum in French is here. You can expose your problem in French there if you wish.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 6 of 8
I wrote it in french beacause it is faster for me to copy it from another french support.
here is the solution in case of same pb for everybody ....
Translate with google in case of need :
En fait je m'auto-réponds pour faire partager la solution au cas ou ....
J'ai eu la hotline (un certain Jimmy A.) qui a été très patient et collaboratif et je l'en remercie ....
Voici ce que nous avons fait devant le constat un peu bizarre.
Nous avons
- supprimé l'install actuelle de Fusion.
- fais un nettoyage propre de Fusion (https://knowledge.autodesk.com/fr/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/FR...)
- reinstallé la toute dernière version à partir du site ("Gérer les produits et Téléchargements" dans la console internet autodesk ...)
Cela a été long mais ce fut bon ....
je peux donc ré-ouvrir mes projets de partout ...
Encore merci
Moderator note: auto translated:
In fact, I answer myself to share the solution in case I need to share it with others ....
I had the hotline (a certain Jimmy A.) who has been very patient and collaborative and I thank him for that ....
Here's what we did in front of the a little bit weird observation.
We have
- Removed the current install of Fusion.
- do a clean cleanup of Fusion (https://knowledge.autodesk.com/fr/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/FR...)
- reinstalled the latest version from the site ("Manage Products and Downloads" in the autodesk web console ...)
It was long but it was good ....
so I can reopen my projects from everywhere ...
Thanks again
Message 7 of 8
Doesn't work on my construction machine in spite of cleaning, deleting and probably losing a whole mountain of files. B... autodesk.
2-week old Fusion360 won't update and won't reinstall, in spite of hours cleaning etc. The install operation gets to 96%-97%, then rolls back to, say, 94% and tries again. I have tried to follow the fault instructions but no luck. (Who pays for the ca. 10 hours to date wasted on this?) Any further ideas? Thanks in advance.
Message 8 of 8
TheCADWhisperer
@Anonymous wrote:
 Any further ideas?
Let's start from the beginning.
Can you start a new thread discussion?
Q1. What are your system specs?
