Pattern quantity validation bug
bradking852
Observer Observer
bradking852
Observer
Observer
F360 will lockup/crash if you start to type a number into the quantity field for a pattern that is too large for your model - the validation does not appear to function. The crash occurs as you type and before you attempt to leave the field.
An example of this problem is that I had a value of 10 in the quantity field for my pattern and I wanted to change this to 20. I clicked into the quantity field, neglected to highlight the existing value of 10, pressed the "2" key and then the "0" key and F360 instantly locked up and then crashed. The number does not have to be particularly large - just large enough to be impractical for the model in question. And you do not get a chance to spot or correct your mistake because the crash occurs as you type and before you attempt to leave the field.
There needs to be some kind of validation as part of the "live" view of the pattern.
mohammed.aliTDPXK
Hello @bradking852 ,
Could you please share the CER report ID of the crash?
I tried this issue but was unable to reproduce this.
Would it be possible to attach the model here?
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
