Pattern on a Path - Spacing
rvrhino64
rvrhino64
When I try and use Pattern on a path to space features a certain distance from each other I get odd results. I tried spacing a 1/2" square 1" apart along a path, but when I check the dimension from the start of one square to the start of the next the dimension is only 3/4" instead of 1". Any help would be appreciated.
g-andresen
please share the file
File > export > save as f3d on local device > attach to next post
günther
rvrhino64
See attached
g-andresen
1. move start point to   0
2. try rectangular pattern instead pattern on path
günther
wmhazzard
There is a years old bug with pattern on path that Autodesk doesn't seem to see as an issue, along with many others, I guess there are not enough complaints about it.
If you start the pattern from zero, it might work for you.
See these threads.
https://forums.autodesk.com/t5/fusion-360-support/pattern-on-path-path-divergence/m-p/11539876
https://forums.autodesk.com/t5/fusion-360-design-validate/pattern-on-path-spacing-distance-confusion...
rvrhino64
Thank you everyone for your assistance, I really appreciate it.
