Hi All,
I have recently ran into an issue whilst using the surface workspace on a surface body. I have been trying to create a closed surface body to form a solid body using the patch tool to close up holes / create surfaces to be stitched to the rest of the body. However, after successfully using the patch tool to close the hole in the surface, all of the edges bar one will stitch to the rest of the body, leaving it as a surface body and not as a solid body.
This issue remains regardless of the tolerance I use; Fusion identifies the free edge and states it has a gap of < 0.05 mm, but even setting the tolerance of the stitch operation up to > 1 mm (even up to the maximum of 10 mm) does not stitch this free edge. Research suggests the edges may not be aligned which is preventing the stitch from working successfully, but I cannot see how this is the issue when the patch operation is used successfully to create the surface body I am trying to stitch.
Please see the attached screenshot below of the issue.
Post-patch and pre-first stitch attempt:
Not all edges stitch, so when trying to stitch again this shows:
Thank you!
