pasted text appears twice upon renaming component
description:
When renaming a component in the project pane the text from the clipboard is added twice instead of once (see screenscast).
system:
Fusion 360 2.0.10032 on macOS 10.14.6
sequence of steps:
- select component so that is has the focus indicated by the blue frame
- use rename function from the context menu to enable name edit
- place the cursor to the end by clicking in the end’s proximity
- use the shift and left curser key to select three chars from the right end
- press apple-c to copy the selected string
- hit enter the leave the renaming operation
- select another component so that is has the focus
- press the right arrow key to place the cursor at the end of the name
- press apple-v to paste the text from the clipboard
- the text from the clipboard is now added twice
- when pasting the clipboard to a text editor the text appears only once as expected
This behavior is repeatable.
Would you please investigate on this issue.
screencast
