I've read and tried a number of fixes identified on the forums here. No luck still. After identifying NLauncher as the application to run, nothing happens. After clearing the file extension association I received the window to use NLauncher again but still nothing happens. Tried it with Fusion 360 open and closed. A second Fusion 360 never opened (One fix was to close duplicate apps). I removed the NLauncher file from C:\Users\{username}\AppData\Roaming\Autodesk\Synergy" and no luck as well. I used Firefox, Edge, and Chrome with the same result. Any other ideas? The only thing it has done is reduce my ticket count. Think I've lost 10 tickets already just trying various things to get this to work. Someone mentioned downloading manually but no mention of how to do that via Parts4CAD or external source. I'll double check the vendor site to see if I can get them manually.
Any help would be greatly appreciated!
