Part upload extremely slow
kthrendyle
kthrendyle
I am trying to upload a single part (.prt file from inventor). The upload time is extremely slow, as much as 7 minutes for a single 250 KB file. Often the upload fails wasting even more time to delete and try again. The upload time has always felt slow for the last 2 years but it seems to be getting worse. I just ran a speed test and my upload is at 10.1 Mbps.
jeff_strater
are you talking about the actual time to upload, or the time to do the translation after the upload?  Translation time can vary a lot depending on the number of other people using the translation services.  Can you share a sample .ipt file here for us to try?
Jeff Strater
Engineering Director
kthrendyle
I'm not sure how to see a difference between uploading and translation. I choose my file, click upload, the status bar jumps to 50%, then sits for several minutes and either succeeds or fails. Sample attached. It is not always greater than 1 minute but when it is slow it is very slow which is usually when I'll get a failed upload.
jeff_strater
strange.  I did not see that.  I do see that the upload stops at 50%.  That is what I think is the difference between upload and translate - that pause.  But, I only saw about a minute delay before the translation was complete.
Jeff Strater
kthrendyle
@jeff_strater  Should I be expecting a 1 minute translation time for a 250 Kb part? It's definitely better than several minutes but 1 minute still feels extremely slow for such a basic model.
jeff_strater
in short, yes.  The time for translation can be variable, depending on level of traffic on the translation servers in the cloud.  But, there are a lot of actions that take place - uploading the part, finding a worker to do the translation, sending the part to that service, doing the translation, creating the resulting Fusion design in your hub, etc.  If you do a bunch of parts at the same time, I would expect some efficiency from doing them at once, but yes, that is within my experience and expectations.
Jeff Strater
kthrendyle
Thanks for the clarification.
