Fusion Support
Part not fading out correclty in animation
2 REPLIES 2
autodesk1VGX4J
575 Views, 2 Replies
I've run into an issue with Animations and trying to fade a component out (or in).  They won't fade all the way out and sometimes remain partially transparent when fading in.  The same issue appears when scrubbing the timeline during editing.  When scrubbing the timeline the results are unpredictable and unrepeatable, sometimes it works fine, but often it fails to fade fully in or out.
2 REPLIES 2
in reply to: autodesk1VGX4J
I also have this issue. I am not seeing any fade effect even though there are nice long fade periods in the storyboard. The parts concerned are just popping on and off at the starts and ends of the fade periods respectively.
karina.harper
Hi @Anonymous
Can you share the file here?
I found this forum thread where this happens with certain appearances. I wonder if it's something like that.
Also - in the future, you'll get more responses if you create a new thread and link to this older one.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
