Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Parametric Dimensioning Not Working
1 REPLY 1
Farzad_K
178 Views, 1 Reply
Hi.
First, I have been having difficulties with ScreenCast because it wants me to sing in but it does not say that I need to sign into Techsmith in which I have a couple of personal accounts and to which I always have difficulties logging in, but that is a different story; I think I have posted to the Support on this issue and I don't believe I have heard back.
Now to the main issue: occasionally when I want to assign a parameter to a dimension, the formula appears to work but I just can't get out of the dimension field except if I press escape at which time the dimension will revert to being not parametric. I am attaching a video I made of the basic old Techsmith's Snagit, and I have posted the model as well.
What could be the problem with the parameter not being assignable?
Thanks in advance.
Farzad
1 REPLY 1
Farzad_K
in reply to: Farzad_K
I discovered the problem was the fist dimension was a negative 1mm (it was an offset) and I was assigning the same variable to a dimension that was positive, apparently. Changing the parameter name to -gap made it work.
Farzad
