Parameters with parametric text plugin
nattybyrneUCEL2
nattybyrneUCEL2
Community Visitor
Community Visitor
I am getting the following error message when I use the change parameters option in fusion 360,
I got a file from a friend and that changing one of the parameters to change a radius and also it is meant to change the radius written on the product
however when I click on OK, on parameters i get this message:
I have installed from the autodesk fusion 360 app store plugin:
"ParametricText"
Some screen shots below include what done / happen with extra text, i entered on them.
ParametricText v 2.3.0 error: 5 : MoveFace1 / Compute Failed // ASM_REBL_REMOVE_FAILED - An existing fillet or chamfer could not be deleted.
Try suppressing or deleting existing fillets/chamfers before attempting the operation. // ASM_REBL_REMOVE_FAILED - An existing fillet or chamfer could not be deleted.
Copy this message by taking a screenshot. Describe what you did to get this error or record a video.
Fusion 360 v. 2.0.15509
C:\Users\Nathaniel\AppData\Roaming\Autodesk\ApplicationPlugins\ParametricText.bundle\Contents\thomasa88lib\events.py failed:
Traceback (most recent call last):
File "C:\Users/<user>/AppData/Roaming/Autodesk/ApplicationPlugins/ParametricText.bundle/Contents\thomasa88lib\events.py", line 142, in catcher
func(args)
File "C:/Users/<user>/AppData/Roaming/Autodesk/ApplicationPlugins/ParametricText.bundle/Contents/ParametricText.py", line 1362, in update_cmd_execute_handler
update_texts(*async_update_queue_.get())
File "C:/Users/<user>/AppData/Roaming/Autodesk/ApplicationPlugins/ParametricText.bundle/Contents/ParametricText.py", line 1322, in update_texts
text_updated = set_sketch_text(sketch_text, evaluate_text(text, sketch_text, next_version))
File "C:/Users/<user>/AppData/Roaming/Autodesk/ApplicationPlugins/ParametricText.bundle/Contents/ParametricText.py", line 711, in set_sketch_text
check_text_height_bug(sketch_text)
File "C:/Users/<user>/AppData/Roaming/Autodesk/ApplicationPlugins/ParametricText.bundle/Contents/ParametricText.py", line 790, in check_text_height_bug
sketch_text.height = test_height
File "/packages\adsk\fusion.py", line 74886, in _set_height
return _fusion.SketchText__set_height(self, value)
RuntimeError: 5 : MoveFace1 / Compute Failed // ASM_REBL_REMOVE_FAILED - An existing fillet or chamfer could not be deleted.
johnsonshiue
Hi! This could be a bug with the "ParametricText" plugin. Based on the review page of the pluggin, there was a similar incident back in 2020. Scroll down to the bottom to see the discussion. You may want to add your comments there too. The vendor will take a look to understand the issue better.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=2114937992453312456&appLang=en&os=Mac
Many thanks!
Software Test Engineer
