I'm modifying a post for a linuxcnc lathe to support the 'D' parameter in linuxcnc G76. (this causes the thread to cut at a tapered angle). I've modeled a 1/4 NPT taper, and used the dumper post to look at the parameters available to 'OnCyclePoint'. For the life of me I can't see anything that indicates it's cutting a taper, let alone a 1.788 degree taper. Where would this info be found?
