Parameter restrict contact with another component.
cmullaneNH3DR
cmullaneNH3DR
I have setup parameter to adjust the dimensions of my assembly. How can I prevent the components from overlapping each other. Basically not allow the parameter work if there is contact with another component.
https://autode.sk/3F6X0u0
jhackney1972
Fusion 360 does not support to use "Conditional Expressions" in parameters.  You may be able to do it using a mathematically equation between the two components, not sure without studying your assembly.
John Hackney, Retired
cmullaneNH3DR
Yes, I believe I can do it using an equation. Thank you!
