Announcements
Parameter not shown when editing circular pattern
hamid.sh.
hamid.sh.
I have created a circular pattern with Angular Spacing set to Angle and entered a user-defined parameter as the Total Angle. It works and gets updated when change the parameter. However, when I hit Edit Feature for this pattern only the value is shown, not parameter or equation, and fx is not shown in front of it (but Fusion knows this is parameter-driven and applies changes). This doesn't happen in Rectangular Pattern or other solid features I tried.
My Fusion is 2.0.12160.
Screencast is here and file is attached.
Edit (a feedback): it would be nice if in addition to Total Angle, Angular Spacing option was possible (i.e. similar to Extent and Spacing options in Rectangular Pattern).
Hamid
jeff_strater
yes, this does indeed seem to be a bug.  I created bug FUS-97714 for this issue.  Thanks for reporting it.  Rectangular pattern seems to work OK, but Circular does not...
Jeff Strater
Engineering Director
g-andresen
Hi Jeff,
Perhaps with this action it is also possible to implement the frequently mentioned option for parallel alignment of features.
günther
