Parameter Not Being Saved In "Circular Pattern"
Can anybody help?
I have created a 3d model of a chain sprocket and I have also created a number of parameters.
One of these parameters in called "NumberOfTeeth".
If I set this parameter in the "Circular Pattern" as "NumberOfTeeth" (please see the picture) the number of teeth in the 3d model correctly changes to the number of teeth that I have specified in the parameter.
However, the parameter "NumberOfTeeth" does not get saved in the "Circular Pattern" dialog box once I have pressed "Save". It only has a integer value.
Is this a "Bug" with Fusion 360?
Can you get "Circular Pattern" to save a parameter in the dialog box?
Many thanks in advance!!!
Darren
