Panel split lines
chawl017
Message 1 of 1
Panel split lines
chawl017
I have been trying to create organic forms with a consistent wall thickness, using multiple separate panels. I have been trying to create the split lines for these panels using a surface to cut through the object, however given the surface is not perpendicular to the form there is a section of wall clearly visible from the exterior. Is there a method in which I can create a surface that is perpendicular to the overall form at every intersection?
Any help would be greatly appreciated
I have attached the working file.
Thank you
Replies (0)
