Announcements
Overconstrain bug I think
martin82DQ5
martin82DQ5
I think found an overconstrain error.
screencast: https://autode.sk/3G4mgm4
HughesTooling
I think the problem is because you're dimensioning off an offset. If you try adding the dimension to the outer rectangle there's no problem. Also works if you use endpoints rather than selecting lines.
Here I've selected the end points.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
By the way I don't think this is a bug because you're not allowed to use an offset to drive the source curves.
In the simple example below you are not allowed to dimension the inner offset rectangle to drive the source outer rectangle. If anything the workarond I gave you above is a bug that shouldn't work, @jeff_strater what do you think?
Mark Hughes
