Orthographic view not rendering correctly
LaleveeJT
LaleveeJT
Trying to show a detail of a bar top in a render but the render keeps coming out all black and appears to show the model in a low resolution. I'm able to get perspective views and other orthographics to render correctly, but not this orthographic view. It does appear to be cutting into the model, since the lower apron seems to only show the side section. Not sure why this would happen, since the viewport window does not show this. I have confirmed I I have the camera set to "Perspective with Orthographic Faces".
Attached is a screenshot of the render preview window along with the rendered result exported. Also attached the file itself. View I'm trying to get is named "Detail" under named views.
LaleveeJT
Anyone?
SallyYang
Thanks for reporting this issue to us and sharing the design models to help us recreate the issue. I can reproduce the issue with this model easily. And I will report it to the develop team. But before we have a solution, will you please zoom out a little bit and render again to see if it meets your expectation. I tried it just now, and I could get the model rendered correctly if I zoomed out a little bit.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
SallyYang
Just for internal track, the issue has been reported as FUS-80054.
Sally
Sally Yang
Autodesk, Inc.
LaleveeJT
Thanks for getting back to me. I was able to get a render by zooming out a bit. It seems like the "lens" of the camera is intersecting with the model and cutting it off in the previous renders. I'll admit, this isn't a huge issue and it's easily fixed by zooming out, but it would be nice to be able to get those zoomed in detail shots in orthographic views.
Thank you for your help.
