I am trying to generate several components in one drawing. I find too much inadvertent interaction between components. I move a body or fix a sketch in one component and then I find it screwed up the bodies and sketches in other component! I spent a lot of time thinking about origins. So I go to a sketch, and spend half an hour moving the entire sketch to the origin, only to find out the origin of the sketch (when I exit the sketch mode) is not the origin of the model!!! I try and select sketch components to move to the origin, but NOTHING happens. I though everything could be moved. I just don't get it. Some sketches show a lock, most don't. How do I change that?
Questions:
- Can I lock a component and sketches so I cannot alter them once I have completed them?
- How can I be sure I am drawing sketches at the drawing origin and not the component origin?
- Is there workflow cadence that I am missing??
Bob
