Announcements
Origin Axis
KLathwell
Origin Axis
KLathwell
HI Guys.
When I first set-up my drawing origins it looks fine and I can work with it, after I complete my first model and then I try to sketch on a particular origin, the top in particular, fusion spins my model around to show the revers origin to what I was originally working to.
Aplogies that I have not learnt how to screen cast yet
jeff_strater
From your description, I am unsure what the problem is.  The sketch view looks correct to me.  What did you select to create your sketch?  If you are concerned that the view is changed to look at the sketch, uncheck "Auto look at sketch" in your preferences.
Jeff Strater
Engineering Director
jhackney1972
This was an issue if a past version of Fusion 360 but was addressed in one of the latest updates.  I would make sure you are running the latest version of Fusion 360.  It is 2.0.15050.  You can find it under the question mark (help) in the upper right hand corner in the drop down menu by selecting "About".
John Hackney, Retired
KLathwell
Thanks for the comments John.
Apparently it is an issue with Fusion 360 but all is good now
