Announcements
Organizar Function
silvibosch
Organizar Function
silvibosch
Hello everybody,
I'm talking about the function that allows you to lay the pieces of a design flat and then be able to cut them with the CNC.
Since the last update, I have not been able to use it because the system crashes.
Do you think the problem will be resolved soon? Because I used a lot.
Thank you.
Silvina Bosch
jhackney1972
Are you referring to the Arrange Command?  If so, in the Windows Fusion 360 environment it works just fine now.  If this is not what you are referring to, please clarify.
John Hackney, Retired
