ORDINATE
chris59UY9
ORDINATE
chris59UY9
Im trying to create the Ordinated dimension at the corner of the part, The X-axis works correctly but Y Y-axis drives to c/l of the radius.  I have tried picking the two edges using the dotted green line method but it still drives to the c/l of the radius.Screenshot 2023-11-19 091041.png
jhackney1972
The Forum needs your MODEL to see if the is a problem with.  Please attach it.
Edit: The attached video will show the process.  It helps if you zoom up real good.
John Hackney, Retired
