Announcements
opslaan in DWG en DXF
infoNJD7M
infoNJD7M
Hallo,
Ik heb een probleem met Fusion in het opslaan in DWG en DXF. Als ik een onderdeel opsla in deze bestanden en stuur ik naar mijn snijder dan krijgt hij een andere maatvoering, ik teken natuurlijk in mm maar als het bedrijf deze open dan is de maatvoering niet goed, de maatvoering is dan in inch! Is dat normaal of heb ik een verkeerde instelling?
Stylyts
rohit.bapat
Hello @infoNJD7M
I am not well versed with Dutch language but what I gathered is that, you are creating the model in mm and then exporting the drawing of this model as dxf or dwg and the units turn out to be in inches.
Am I right in understanding the issue?
I would like to know the units set in your drawings? You can set the default unit of the drawing in the Create Drawing dialog as below
Please let me know if I missed something.
Rohit Bapat
Product Owner
infoNJD7M
Best,
Thank you for your answer and interest. And you're good with your thoughts.
But I think I have everything right, with Drawing but also with Preference. Everything is on mm. But when I transfer my DXF and DWG to the cutting program, the dimensions change. It is not the cutting program, the manufacturer even suggested Fusion. If I import a drawing from SolidWorks as DXF it's fine! I think it's really weird but I'm okay with it. Now I have to draw in mm, before I save the design as DXF I have to change the setting to inch and enter it into the program.
