operating system problem
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001DF6A865190> #
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\resources\buildinfo.json
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\resources
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\certs.pem
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001DF6A855F80>, operation=<function multiple_operate at 0x000001DF69F35EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 18:42:23,129 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 18:42:23,192 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 18:42:24,051 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 18:42:24,082 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 18:42:24,223 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A890C10>
2024-07-07 18:42:24,223 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,566 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A7850>
2024-07-07 18:42:24,566 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:24,582 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,582 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A7710>
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A75D0>
2024-07-07 18:42:24,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:25,613 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 2838caf6-bdd6-4ae6-bc2c-07b88e06f35d
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 18:42:25,676 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002AA846496D0> #
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\resources\buildinfo.json
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\resources
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\certs.pem
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002AA84635F80>, operation=<function multiple_operate at 0x000002AA83D15EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:05:18,529 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:05:18,591 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - ERROR :: Failed to log network information because of exception [Errno 11001] getaddrinfo failed
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get network connection information [Errno 11001] getaddrinfo failed.
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is not accessible
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- FAILURE
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Failed to get apps.
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {'CheckNetworkConnectivity': '{"description":"VW5hYmxlIHRvIGNvbm5lY3QgdG8gTmV0d29yay4gUGxlYXNlIGNoZWNrIHRoZSBjb25uZWN0aW9uLg==","url":"aHR0cHM6Ly9rbm93bGVkZ2UuYXV0b2Rlc2suY29tL2FydGljbGUvUHJlY2hlY2stTmV0d29yay1Db25uZWN0aXZpdHktaXNzdWUtRnVzaW9uLTM2MA=="}'}
2024-07-07 23:05:18,794 - MainProcess(4616) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.analytics - INFO :: Sending analytics for command "Deploy.NetworkConnectivityError" args: [None, None]
2024-07-07 23:05:47,439 - MainProcess(4616) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.analytics - WARNING :: Failed to send data to ADP because of exception 'NoneType' object has no attribute 'split', command "Deploy.NetworkConnectivityError" args: [None, None]
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- FAILURE
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Failed to get apps.
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {'CheckNetworkConnectivity': '{"description":"VW5hYmxlIHRvIGNvbm5lY3QgdG8gTmV0d29yay4gUGxlYXNlIGNoZWNrIHRoZSBjb25uZWN0aW9uLg==","url":"aHR0cHM6Ly9rbm93bGVkZ2UuYXV0b2Rlc2suY29tL2FydGljbGUvUHJlY2hlY2stTmV0d29yay1Db25uZWN0aXZpdHktaXNzdWUtRnVzaW9uLTM2MA=="}'}
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002741AF596D0> #
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\resources\buildinfo.json
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\resources
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\certs.pem
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002741AF45F80>, operation=<function multiple_operate at 0x000002741A625EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:07:52,542 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:07:52,605 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:07:53,402 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-07-07 23:07:53,402 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
2024-07-07 23:08:47,581 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:08:47,581 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000200BAEE96D0> #
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\resources\buildinfo.json
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\resources
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\certs.pem
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000200BAED5F80>, operation=<function multiple_operate at 0x00000200BA5B5EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:09:07,392 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:09:07,470 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:09:08,283 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-07-07 23:09:08,283 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
2024-07-07 23:09:34,688 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:09:34,688 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000028249BC96D0> #
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\resources\buildinfo.json
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\resources
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\certs.pem
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000028249BB5F80>, operation=<function multiple_operate at 0x0000028249295EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:09:39,000 - MainProcess(2352) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:09:39,000 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:09:39,250 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:09:39,297 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:09:40,094 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 23:09:40,109 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:09:40,203 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249BF2BD0>
2024-07-07 23:09:40,203 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,422 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C07510>
2024-07-07 23:09:40,422 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,437 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,437 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C073D0>
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,640 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C07290>
2024-07-07 23:09:40,640 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 4b88f004-dba2-4940-80f5-4711907c1dfd
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 23:09:40,937 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2024-07-07 23:10:39,980 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:10:39,980 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001B5F78E96D0> #
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\resources\buildinfo.json
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\resources
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\certs.pem
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001B5F78D5F80>, operation=<function multiple_operate at 0x000001B5F6FB5EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:10:48,703 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:10:48,766 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:10:49,906 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 23:10:49,922 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:10:50,016 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7912BD0>
2024-07-07 23:10:50,016 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,234 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7927510>
2024-07-07 23:10:50,234 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,266 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,266 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F79273D0>
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,437 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7927290>
2024-07-07 23:10:50,437 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is bdc9ecf9-e13e-477e-a35a-da074cd2b92d
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 23:10:50,734 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
