Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Opening A Specific File causes Fusion 360 to Close Unexpectedly
6 REPLIES 6
nhung5111
214 Views, 6 Replies
I just worked on this file yesterday and when i open it today it says this in the crash report detail:
Crash ID: 722231570
Date/Time: 2023-10-07 20:30:59 -05:00
Application: Fusion360.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: tsplines11.dll
Exception Address:
Exception Code: c0000005
I have tried uninstalling Fusion, clear cached, but nothing works. I can open any other files that i have but not this one. Please Help i've put so many days of work into this.
6 REPLIES 6
Phil.E
in reply to: nhung5111
Thanks for letting us know. Did you get a chance to send in a crash report? They look like the image below.
Send every crash reportSend every crash report
If you can provide a report number I'm happy to look into it. If you are willing to share the design, please PM me with a link to download it. I'm happy to log a bug report for a repeatable crash. I can also check if it is a known issue.
Phil Eichmiller
Software Engineer
Quality Assurance
nhung5111
in reply to: Phil.E
Hi, Fusion 360 just had an update to solve this issue and i can open my files now, thank you for helping. You guys are awesome.
brane421
hello, I have same problem, I send few reports for it. Can anyone help me please
Phil.E
in reply to: brane421
Phil Eichmiller
Software Engineer
Quality Assurance
brane421
in reply to: Phil.E
Thanx for quick reply, Report ID is 734677311. if needed I will PM you my design. I try to make another setup for some operation which in first setup made Fusion crash, and in other setup it worked ok
Phil.E
The crashes are related to In Process Stock. Turn off In Process Stock, then try to open the design.
Phil Eichmiller
Software Engineer
Quality Assurance
