I would like to set my post processor and have it stick. Every time I post process I have to manually select to correct post processor.
@cole Are you using any machine in there? to be precise if you are using machine simulation model then the post processor will be always sets to machineSimulaion.cps file by defaul
but of course it can be changed by default as mentioned below
Thank you Boopathi!!!!!!
My options were a little different but you put me on the right path. I did it in Machine Configuration.
You have click on the Select button to get the same option like me not on the Edit.
But like as you said both works
