Fusion Support
old files
3 REPLIES 3
petesantavicca
207 Views, 3 Replies
old files
after using and learning fusion 360 the last two years, i have generated several small projects for my 3d printer. at the age of 76 years old and retired, I requested for "Fusion 360 personal use". I now can not retrieve my working files on the new Fusion 360. How can I retrieve my old files to be able to modify them. Help
3 REPLIES 3
If you use the same Autodesk ID with your past Fusion 360 and your present, the files should be available.  If you did not, you may have to log into A360 using your old Autodesk ID and export them to your local drive, reopen and then save to your new Autodesk ID cloud account.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
thanks, it worked
yoeproth
in reply to: jhackney1972
I cannot find my files from 3years, before the update I knew where to find it though.
Any idea?
