Announcements
Offsetting shape stopped creating a plane to extrude - BUG REPORT
r.augusiewicz
Message 1 of 22
r.augusiewicz
I am working with few same vectors for over a year or even two that I regulary put into the sketch, offset the outline to any number between 0,1 - 3mm and extrude the outcome profile. It worked like 100% times, for each vector, always, for months - zero problems.
Something got broken with a new update, maybe something with offset calculation?
Now in like 99% cases when I offset I always get empty (open?) plane that I can't extrude. In the range of 0.1-3mm only few numbers are working like in a lottery when in past it was just solid 100% with every of my vectors. Nothing has changed with my workflow nor with the files.
I have the "Show Profile" option checked.
You can check the included vector as a sample - resize it to somewhere between 6-10cm and try to offset the outline. No luck for me, only few numbers working.
Very, very bad timing for me. Help would be appreciated 🙂
Replies (21)
Message 2 of 22
r.augusiewicz
Refreshing this topic, because for me it is a very serious problem. Something has dramatically changed with offset and it is not caused by faulty vectors - all of them don't work for me.
I need a support here.
Message 3 of 22
r.augusiewicz
I can take the same vector to Lighburn, which is also vector software, I can offset the outline by ANY given number and it ALWAYS creates a plane that is closed and can be set to "fill" by a laser let's say.
I can take that offsetted vector, export it, open it in Fusin and offsetted lines work as they should - they are closed plane and can be extruded.
This is clearly a very annoying bug in Fusion 360 that was implemented with a very recent update.
This really needs to be addressed.
Message 4 of 22
r.augusiewicz
I am not sure why my post received zero attention, I have pointed a very clear bug and provided some steps to reproduce it and proofs that it started to happen with latest update.
Maybe it just got lost in all the topics.
Just trying to call people I think are related to this section
@CGBenner
@Phil.E
Message 5 of 22
jhackney1972
I looked at your issue when you first posted it and could never replicate the issue your speak of.  I have posted my process in a Screencast to show what I did.  Please take issue with the process and/or create your own to show the issue.  I cannot replicate it.
John Hackney, Retired
Message 6 of 22
TrippyLighting
This is a known issue with imported vector graphic files (.svg and .dxf).
The connect the dots plugin might help.
Message 7 of 22
r.augusiewicz
Please take a look at my screencast.
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/aefaa7a1-fba6-43b9-9a0f-c5a163dc5aa3" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 8 of 22
jhackney1972
This is not the same SVG in your original post.  Please attach this one to another reply.
Message 9 of 22
r.augusiewicz
New screencast with original SVG @jhackney1972
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/89c2f823-d0ac-4d4a-87f2-00eaffdfc72e" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 10 of 22
r.augusiewicz
Please take a look at my screencast in post above - it explains and shows this bug very clearly. I can open all of my old vectors  and I can't even make the offset to work even once with a distance I desire.
This is not a coincidence.
Message 11 of 22
jhackney1972
`Watched it numerous times.  Still, you need to post the SVG you used in the Screencast as I could not make the original one fail so I need the one you say gives you an issue.
One more thing, user the Reply icon to the person you are responding to so you do not respond to YOURSELF.
Message 12 of 22
TrippyLighting
@jhackney1972 I found this easy to reproduce with the attached .svg. The offset works but does not create a closed shape, indicated by the white dot.
This is a persistent issue with imported vector geometry.
Message 13 of 22
r.augusiewicz
Yes, I just noticed the replying to myself function and I was sure this is why you are not getting the notifications, sorry!
The vector I am using in the last screencast, which is the most clear and obvious for audience I think is the same vector I have attached in the first post. Attaching it again.
I really do feel left alone with this bug. I am providing screencasts of Fusion 360 function clearly broken and it sounds like at the end I will get the "it works for me" answer from Autodesk, even so we are all working on the same on-line version of it.
I feel like me discovering such issue is an unwanted problem of some kind.
Message 14 of 22
r.augusiewicz
Is there any work going on with it? T
his really had to come up in the newest update, I was working with those vectors for some crazy hours daily  and I have never encountered it for past 2 years. Now it happens for like ALL of my old vectors - it is not "from time to time", this is 100% broken now, and before a week or so it worked as it should.
Message 15 of 22
jhackney1972
Ok, I got it to fail a couple of times.  On another post, about an SVG failure, I used a web conversion site to do a double conversion.  I first converted the original SVG to a PNG and then converted the PNG to an SVG.  This seems to repair "small" problems in the original SVG.  In the case of yours, it seems to have found a double exterior boundary during the conversion but other than that, I do not see any failures when I use it in the process you described.
I admit this is a workaround but it may get you over your issue and allow you to move on with your work.  The Converted SVG file is attached.
Message 16 of 22
r.augusiewicz
- Is there any chance that somebody will log it as an official bug and start to work on it?
- Is there someone who is in charge of updates/bugs and would get interested in that case and send the information further so that it could be addressed properly?
Just saying, because converting SVG on public converter to PNG and then back to SVG, and compromising my file privacy to the third party site doing that, is you know, kind of sad workaround for that kind of a powerhouse software, especially that once again - this bug was introduced very lately, I can point to almost exact day when it came with an update, and that should speed up the debugging process greatly.
I really don't want to part with this software, I don't want to look for a replacement, but come on - no one is giving here any clear answers on what is going on or is willing to push this issue on official manner.
This is a new bug, not something old and hard to repair. Someone updated and broke the software.
Sorry if I may sound pissed, I try not to, but I am just very dissapointed. First my whole topic about a very important bug went silent with zero answers, then I am providing 100% accurate, screencasted and well explained problem, I am even giving a very important information that it was not there few days ago (should be very helpfull) and still nobody cares except the people I have forcefully summoned by tagging.
Message 17 of 22
Phil.E
Thanks for reporting this issue. I was out last week on family leave and didn't notice your post.
This is logged as FUS-106662.
At this early stage, there is no way to predict when or if this will be fixed, so please use the workarounds provided by the community until an informed response is possible.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 18 of 22
r.augusiewicz
Thank you, great to know!
Is there any chance I could be informed if any estimated time or priority of the bug will be known?
Rafał
Message 19 of 22
Phil.E
This is not something that is easily done. (tracking every single bug back to the customer forum post) If you had a commercial license and filed a support ticket the support team could be able to track it. I'll add a note to the ticket to update this thread once the fix is in the release pipeline.
As for priority I cannot say. This is up to the individual development team. Importing SVG is not a mainstream manufacturing commercial workflow, but sketch offset is. So I don't know how it will be treated.
In general it takes months to get a fix because we have to log, triage, test, debug, fix, test and release the fix. That takes time.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 20 of 22
r.augusiewicz
Hello! Have anything moved on with this bug? It still occurs and Fusion 360 lost a great feature and it seems that it is not an important thing to fix at all.
