Fusion Support
Offset Sketch lines to new Sketch?
4 REPLIES 4
markmorb
105 Views, 4 Replies
Hi
I have an SVG imported which I have projected onto a Sketch, from there I've created an offset of a few millimeters all around the edges. Problem I'm having is I want to extrude the Offset Sketch as a single body object but in order to do this I have to manually delete all the other sketch objects inside the offset sketch line first. Is there a way for the offset Sketch Line to be created as a new sketch on it's own, or alternatively, is there a good way to delete all the sketch objects inside an offset sketch line.
Thanks for your help.
Mark
4 REPLIES 4
HughesTooling
in reply to: markmorb
Rather than deleting the projections can you make them constriction lines? Just select the projected curves and press X to change.
Mark Hughes
Owner, Hughes Tooling
davebYYPCU
When you have the new outline, window select all, for the extrude.
Might help….
HughesTooling
Just did a quick test and found if you convert all the projections to construction geometry you can offset and create normal geometry without needing to make changes after offsetting.
So below I set the line type to construction then projected the rectangle. Then I toggled the line type to normal and then created the offset.
Mark Hughes
markmorb
Some interesting ideas there...I'll give them a go and report back. Thanks 👍
