Announcements
Offset plane appears to create a line, not a plane.
FrodoLoggins
Advisor Advisor
FrodoLoggins
https://youtu.be/8Ed3R1jQTf4
Model not created in Fusion, either solidworks part or STEP can't remember.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
jhackney1972
There is nothing wrong with the plane, it is just folded up on itself, see Screencast.
John Hackney, Retired
Thanks John! That's really helpful. I've encountered this problem and I just did a delete and make a new one. Your way is a more elegant solution to the problem.
jhackney1972
If you feel you have a solution to your forum question, please select the Accept Solution icon so other can find the answer to similar questions.
FrodoLoggins
Every offset plane I'm making are all folded, is there a hotkey I might have pressed?
jhackney1972
If you are in the same model, there were a lot of surfaces that created an offset work plane as a folded up line.  There is no special method of creating an offset work plane as I know.  Create a simple new "brick" model and try it, I think it will work as expected.  I do not know where that model you posted came from but....  Let me know how the command reacts on a new simple model.
